Low clearance toilet drain
Discussion in 'Toilet Forum discussions' started by Frankbranch, Apr 4, 2021.
  1. Frankbranch
    Frankbranch New Member
    Sep 1, 2016
    Tennessee
    I would love to buy you a beer or two or three. Just wish I had a good plumber I could call who would actually show up sober. Anyway, sounds like the spigot closet bend is the best shot, will also get some parts for a plan B and modify as we go along.
  2. wwhitney
    wwhitney Well-Known Member
    Mar 17, 2019
    Berkeley, CA
    So the 1-3/4" thickness includes the finish floor? As I imagine you don't have exposed OSB in the bathroom. And the closet flange gets installed on top of the finish floor, not on the subfloor.
    If so, that explains the discrepancy.
    Cheers, Wayne
  3. Frankbranch
    Sep 1, 2016
    Tennessee
    Correct, it includes the underlayment / vinyl finish floor. Plan to upgrade that at some point in time, but not now. I measured it via sticking a tape measure through the hole left by an earlier CPVC supply line.
  4. wwhitney
    Mar 17, 2019
    Berkeley, CA
    Changing the finish floor elevation in the future would be easier if you use an outside fit compression flange or an inside fit barbed non-glue flange.
    Cheers, Wayne
  5. Frankbranch
    Sep 1, 2016
    Tennessee
    I went with the outside compression, was concerned that the inside barbed versions required more length in the spigot end than I would have available. Going to have a bunch of extra parts, being in a rural area a trip to a supply house eats a good chunk of a day, so I always buy extra. Thanks for all your help.
    Tuttles Revenge likes this.
  6. Tuttles Revenge
    Tuttles Revenge In the Trades
    Oct 15, 2014
    We recently used an outside clamping style on a project where the flanges had never been secured to the floor. The old ones, which were the exact same model, were a bit difficult to remove once they had been on for a LONG time on cast iron.. You'll probably have better luck with them on plastic pipe.
  7. Frankbranch
    Sep 1, 2016
    Tennessee
    It’s in, got the clearance in the ceiling and back wall. Used a 4” street closet flange and a Otaey clamp on closet flange, came out looking pretty good. First two images are the old work, last is the new. Thanks for all the great suggestions and guidance.
    Tuttles Revenge, Reach4 and wwhitney like this.
Similar Threads: clearance toilet
Toilet Forum discussions 2X8 ceiling joist clearance for toilet flange/elbow Oct 16, 2019
Toilet Forum discussions Space Heater and Toilet Clearance May 17, 2019
Toilet Forum discussions 15” side clearance of toilet, measured to shower curb or shower glass? Jun 13, 2018
Toilet Forum discussions Need recommendations for a toilet that has 3" of clearance for heater May 28, 2018
Toilet Forum discussions Trouble replacing valve in minimal clearance skirted toilet Dec 4, 2016
