Loud water knocking from pressure reducing valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Sohcrates, Nov 10, 2021.
  1. jadnashua
    Does the house pressure change when you change the PRV adjustments? If it say rose from 40psi to 55 as you adjusted, but didn't go further, it may be okay...but if it was at 55 when you started, and didn't change, then either the supply is at 55, or the prv is bad. Sometimes, it nice to have a pressure gauge, or a port where you can check it, both before and after the PRV.
  2. Jeff H Young
    Jeff H Young In the Trades
    Feb 27, 2020
    Definitely good to have a spot that's not on the regulator to check, he might have 55 psi coming in or it could be more impossible to know the pressure based on provided info.
  3. Sohcrates
    Sohcrates New Member
    Nov 10, 2021
    Virginia
    So I still get the occasional knocking. I just tried adjusting the PRV down (instead of up) and it doesn't really change anything. Still hovering around 50-55psi. That alone seems to tell me that it may indeed be a bad PRV at this point.
    Does anyone know if it matters what "type" of PRV I replace it with? I currently have a Watts setup but there seem to be many alternatives out there.
  4. Jeff H Young
    Feb 27, 2020
    I dont think it matters as long as it can supply needed volume. I use watts brand and zurn/wilkins. i guess you never determined the water pressure or if you need a regulator?
    Reach4 likes this.
  5. Bannerman
    Bannerman Well-Known Member
    Mar 19, 2014
    Ontario, Canada
    When reducing the pressure setting on a PRV, a downstream faucet will need to be open slightly so as to relieve the initial higher pressure after the PRV. When there is no water being drained downstream, the pressure after the PRV will not usually change regardless of how much the pressure is being lowered.
  6. Bannerman
    Mar 19, 2014
    Ontario, Canada
    To assist to determine the source of the sound, use a long screwdriver equipped with a hard handle (not rubber covered). Use the screwdriver as a makeshift stethoscope by holding the tip firmly against the suspected source of the sound (PRV, water meter, water heater TPRV or other device). Place your ear against the handle to attempt to determine where the sound will be sharpest and most intense.
    If the water pressure from the city is less than 80 psi, a PRV should not be needed, but perhaps your home is located nearby to a pumping station which may cause the mains pressure in your area to exceed 80 psi whenever that pump is operating.
    Jeff H Young likes this.
  7. Jeff H Young
    Feb 27, 2020
    Tried telling him to check pressure if you don't know what's incoming you can't know if regulator is needed or doing anything
  8. Sohcrates
    Nov 10, 2021
    Virginia
    I am planning to replace the PRV and before I do that I have an adapter to check the water pressure from the city I will install. Planning to do this before the holidays. Will also check with the "stethoscope" to verify where sound is coming from.
  9. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    I would ask the water department if they expect that you need a PRV. Also consider talking to a neighbor or two if they have any knowledge of the local conditions.
    But yes, a way to measure pressure before the PRV is good. I would not like to have a PRV if the pressure from the street is only 55 or 60.
  10. Jeff H Young
    Feb 27, 2020
    We have no idea what the max pressure to the house is only that where and when he checks it, it as least 55 but whether it rises in off times low demand who knows ? We can only repeat these obvious things to the OP and hope he gets it.
  11. Bannerman
    Mar 19, 2014
    Ontario, Canada
    The 200 psi gauge example linked to below, includes a 'maximum pressure' pointer which will indicate the maximum pressure sustained since the pointer was last reset manually. The garden hose adaptor fitting maybe removed so as to thread the guage to an alternate fitting before the PRV.
    https://www.amazon.com/Watts-0950200-Water-Pressure-Gauge/dp/B000YMU8JC/ref=sr_1_6?crid=140LRMJ21UPVI&keywords=water+pressure+gauge+with+max+pointer&qid=1638376435&sprefix=Water+pressure+gauge+with+,aps,341&sr=8-6&th=1
Similar Threads: Loud water
Plumbing Forum, Professional & DIY Advice Cloudy faucet water May 4, 2021
Plumbing Forum, Professional & DIY Advice Cloudy hot water Jan 17, 2021
Plumbing Forum, Professional & DIY Advice Loud water flow in new copper pipes Feb 9, 2020
Plumbing Forum, Professional & DIY Advice Loud popping sounds from water heater after pipes have been drained Nov 16, 2019
Plumbing Forum, Professional & DIY Advice Single loud pop when water turned on AND off Jul 27, 2019
