Neil.Steiner
I drained my water pipes because I need to replace a failing saddle valve on the hot side with a proper Tee and quarter-turn valve.
I began by turning off power to the water heater, turning off the water main, opening all faucets starting from the top of the house and working my way down. The pipes coming out of the WH are higher than the basin whose faucets I opened last, so there should still be some water in the WH inlet and outlet, unless a lot of it was syphoned out.
Somewhat sporadically, but perhaps every 30-300 seconds, I hear a loud pop from the WH, and this has been going on for at least 30 minutes. The WH is much older than I'm willing to admit, but I flush it every year, and don't recall ever hearing loud pops like this before. Much too loud to be drops of water, but that leaves me completely baffled as to what it could be. If the tank was failing, I wouldn't expect the sounds to go on and on. I understand that the tank will gradually cool off, but the popping didn't begin until I drained the water from my system. (I can't upload a sample because this forum doesn't accept .mp3 files.) Under normal operation, the WH never makes much noise.
[I turned off power to the WH by flipping the breaker, and verifying that the input now reads 0V, where it previously read ~240V. I just now double-checked again that voltage is 0V, and I carefully shorted the terminals to prove to myself that I'm not mistaken.]
Any thoughts on what this might be? I replaced the WH TPR valve about a year or so ago, I periodically replace the anode as needed, and have otherwise had no problems with it. When I flush it, the sediment is never very bad.
