Loss of Pressure
dane
Florida
I have a 1 hp Flotec FP5162-08 controlled by an anolog intermatik timer box with a back yard canal as my source ( Florida). I has five zones with anywhere from 4 - 8 sprinklers in each zone. I initially noticed that I was loosing pressure in one zone, however if I cycled the all the zones, on the second run the problemed zone work fine.
Now I am loosing pressure in all zones in quite the same manner. Could this signal that the attached check valve has gone bad?
I have admit that I have noticed some air in the system, but not more than was experienced when system was fully functional. Also when I disconnect the union attachment after the pump, I am able to get very good pressure after a a couple seconds incremental increases ( Water flow starts off low then gradually gets stronger)
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
You probably have a suction leak. Plastic union on the suction side is not a good idea. The o-ring seal will hold good under pressure but not under vacuum.
dane
Florida
Do you have a strainer that could be partly clogged?
Not that i am able to see. Also i got very good flow after I disconnected the union after the pump. But i will look into the possiblilty a bit further. Thank you.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
When running a larger flow rate such as when the union on the discharge is disconnected, the pump draws in more water than air and may pump good. When you restrict the flow rate, such as when running a small zone, the amount of air being sucked in will overtake the smaller amount of water, and the pump will start loosing prime and pumping less water.
dane
Florida
Solution!!
I removed the union before the pump intake and am glad to say it is running better than I have ever seen. Thank you valveman and smooky for your help.
