Leed1315
Pressure dropping slowly I could see with the pump not having enough lifting power. If it was the pump pumping from too deep, I would think the pressure would drop smoothly as the water level dropped, and I am reading this as the pressure dropping suddenly. I am also presuming Leed1315 is saying that the flow dropped suddenly in addition to the gauge indication dropping.
I believe the sudden drop is when the pressure gets less than what the tank pressure is at. If I let the pump build up to 60psi and turn the pump off I can open the valve and once the psi drops below 38 it drops straight to 0 also.
I decide to try your idea about putting the hose in the well and I believe that has solved my problem. When i did this the pump stayed at roughly 58-60psi constant with no drop for at least 20 minutes. When i removed the hose and let the water go on the ground the pressure started dropping and within 5-7 minutes dropped below the 38psi mark and fell out. I was standing beside the well when it happened and it seemed like I could hear the pump almost run out of water. When I pulled the hose out of the well the water was a very orange/brown color. I dropped a rock down the well casing and it was clear that the water was no longer at 26'. It sounded like it was at they very bottom when it hit. When we removed the old pipes they had a lot of orange mud on them. I didn't know what to make of that and we didn't have any trouble puttin the new pump and lines in.
Assuming that with my well condition I'm only getting roughly 10 minutes of solid wide open water what can i do? Should I assume thats just all it can d sor has it got like this over time? Should I see how deep the well actually is? I just pulled the old pipe and went with the same depth assuming initialy it was et at the best depth? Thanks for all the help.
