He mentioned that because it was back on post #3 where you said you were a tenant in a second story apartment. Roots clogging lines of a house is not a DIY thing.
Okay, I see what he meant.
How am I supposed to know that roots can cause a clog?... lol. This the first time I am under my sink doing this sort of thing.
I am learning, though.
That was the only paragraph of post #20 with a question mark.
Yes. I mentioned the whole post (#20) in case you didn't see that post or any other information I may have provided in that post.
I did not know the answer, and I was surprised you were bringing crap back up. Also, when you said empty the drain, I was thinking of the hole in the bottom of the sink bowl. I guess you might have been referring to the plug on the P-trap. Most P-traps don't have plugs.
"...bringing crap back up again."?
I had thought maybe you had missed that #20 post or those two questions, as you didn't answer the questions when I asked them. That's the only reason why I asked you to see that (#20) post.
I am not really sure what are the correct "terms" to use when speaking on this topic. So when I "empty the drain" with a clogged pipe (under the counter), I mean I am emptying everything on either side of the trap, ie: the pipes, whatever is still in the sink and still in the trap itself, by using the trap cleanout hole.
We know that on
my trap there
is a cleanout "hole" or "plug". There are photos of it, and we referred to it.
I want to apologize for my ignorance on the topic of plumbing and all the parts and even the names of tools used in plumbing. I just wanted to make a pot of green tea, and POOF!... here I am with the plumbers trying to unclog my sink pipe lol.
I do not fit into this forum, at all, really lol. I am a guitarist.
If you undid the banded/shielded coupling, you could pull a section of stuff loose, and have nice access for cleaning the piece you temporarily pulled out. It is not as big a deal as I think you are thinking. I have used a 2-inch Fernco Proflex and totally removed the metal. The ends come apart....
I finally undid the banded coupler, only on the left side (the side opposite the steel pipe) and removed that section. Thanks for the insight of what I might find under there. It was easy to undo the clamp with a pair of plyers, and the pipe came out, and will go back in, without any problems.
All that is there now is the wall pipe, the iron elbow, the galvanized steel pipe, and the banded coupler.
Nothing was found in the PVC pipes and in iron elbow, at all, though.
The clog is only in the pipe in the wall, now.
I think the clog must look like a ball of tea leaves and tea leaf twigs and grains of rice (as this type of green tea has all of that in it).
I am not sure if all I will do with a snake is push the clog deeper down the pipe.
I am BOTHERED GREATLY because the clog WAS in the p-trap, at first - but now, it's moved into the wall in the pipe. Sheesh!
I am not sure how far the clothes hanger is going into the wall pipe as I can't see a thing (that is IF it is going IN to the wall pipe at all.
And when I pull the clothes hanger back out, i am not pulling any tea leaves or muck OUT of the pipe, though, so I am thinking the hanger is getting snagged on the pipe somewhere. It's probably NOT even entering the wall pipe, at all.
I placed myself deeper under the counter to get a better look at the pipe in the wall and to see how it's connected to the iron elbow.
Here is how it looks in words:
From the wall, there is a metal pipe (of some kind) with threads on the outside of the pipe.
Those threads were screwed into the iron (female) elbow, (the iron elbow has two female holes)
The galvanized steel pipe (with the banded coupler) also has threads on the outside which screws into the other side of the iron elbow.
See photos. I can't photograph the pipe coming out of the wall due to bad angles.
If I can, first, unscrew the galvanized pipe from the iron elbow, and then unscrew the other side of the elbow from the wall pipe, I could then have direct access to the wall pipe.
It would have to be taken apart in sections because of limited working space.
There is another way to have direct access to the wall pipe, and that is to leave the galvanized steel pipe in place and just unscrew the iron elbow from the pipe in the wall. But I can only do that if I, first, clear off the long, single shelf holding all my pots, and then remove the entire shelf, if possible. I have a small kitchenette and I have no idea how I would even get that shelf out from under there in one piece. This kitchen must have been put together like a game of Tetris, meaning, the counter must have been dropped, section by section, into place from above and, then, built up to look like a kitchen counter, probably before the walls were put up. It's small, in here.
That shelf will surely be in the way with the galvanized pipe attached to the elbow as it will prevent the unscrewing action because the space is too small down there.
I could avoid all of that work, hassle and worry by just buying a snake, right?
The thing is I have no idea how long a snake I should buy. Is a fifteen-feet snake long enough? I would hate to buy a 15 footer and it's too short somehow, leaving me in the unwanted position of having to buy a, second, longer snake.
I'm trying NOT to spend any money (or too much of it) on this.
Either way, it's cheaper than paying a plumber, so if I have to buy a snake, so be it (grumble grumble).
Do you, yourself, know, or know someone who knows, if a snake COULD actually push a clog deeper down the wall pipe?
If only I could get that elbow off, I could have more options.
Options like 1. having direct access to the wall pipe so the clothes hanger could be proven useful or not, and 2. maybe I could put a drain cleaning chemical right down into the wall pipe.
I can't see how pouring a drain cleaner into the sink will clear a clog that is past the trap and in the wall pipe. Is that normally done?
I was watching a video of a plumber who doesn't like using chemicals because he says, "If the drain chemical doesn't work, you will have to deal with it when you start snaking and pulling up junk with drain cleaning acid on the junk and the snake".
He had what appeared to be a really long snake.
In my lease, it does state, "Do not use chemicals in clogged drains".
I wish I would have just unscrewed the trap and got at that clog before it moved down the line. It would have been over by now.
Thanks
