JimandCalli
I'm looking for a well pump recommendation in the Grundfos SQ line for a newly installed well. I've read many many posts on here regarding wells and well pumps. (No rope, no torque arrestors, no pipe centering attachments, check valve only at the pump exit, tape should end on tape, and others!) I'm considering using 200psi 1" poly for the drop and run to the house. I'm also thinking a CSV is the right choice for the new house that will be going up eventually so any pump choice needs to work with that.
According to the well report we received:
Regards,
~jim
- Well depth is 200'
- The well pipe is 120' of 6" iron with approximately 2' sticking out
- Depth to bedrock is 3'
- Well yield is 34gpm
- Static water level is 40' below land surface.
- The highest point in the new house for fixtures will be approximately 6'-8' above ground level.
- The run from the well to the house is ~60'
Regards,
~jim
