Orioledr
Long time viewer, first time poster. Adding half bath to unfinished basement. Drain line is at ceiling height so need to install an ejector pit/pump. Will have two sinks. Bath vanity is adjacent to toilet and pit (less than 5'). Wet bar will be about 15' away. I'd like to use a 2" WYE to combine 1-1/2" drains and 2" vent/drain into pit as well as toilet. My plan is to trench and install 4" drain into pit. I would also have 4" x 4" x 2" WYE in the trench to combine drain line with toilet line.
I have attached a rough sketch. Can I use the 2" vent at drain WYE as the pit vent as well or do I need to run a secondary vent line out of pit and connect to drain vent above the floor? I dont fully understand how the 42"/flood line applies to my situation.
Am I doing this correctly? (The bath will share a wall with a utility room, so I will have access to the pit and rough in plumbing.)
Any other suggestions/criticisms would be appreciated.
