jay manuel
Hey guys, been reading a bunch on here and found some very good information on here but I have question that hopefully someone can help me out with.
I have land in Mississippi that I am building a cabin on in the near future here and I need to run PEX or CTS pipe a total of 2300 feet from the meter to the future homesite. I will be putting the line off the side of my gravel road. From the meter the road rises around 30 feet high and then is fairly flat the rest of the way. The freeze line I am told is 8-10 inches so I will be attempting to go deeper if possible.
The home will consist of approx. 1600 sq ft, 2 bathrooms, kitchen, laundry and have 2 outside facets. The meter size at the road will be 3/4" but I can pay more and get a larger meter. I was told conflicting information by two plumbers this week.
One plumber says to run 1-1/2" CTS HDPE Poly Tubing and the other plumber says to go with 2", both with the 3/4" meter. The 1-1/2" plumber claims that it is adequate with a 3/4" meter and I will have sufficient flow. The 2" plumber says that the flow will not be sufficient with the 1-1/2" and I need to go with 2" but stay with the 3/4" meter. The price difference is close to $800 in pipe and another $200 in the larger fittings for the connections.
The 1-1/2" plumber claims the 2" pipe will not provide sufficient flow being a larger pipe, which I didn't quite understand but I am not a plumber just a DIYer like many others.
Is 1-1/2 inch pipe large enough to provide sufficient flow to the homesite? I wont be living in the home as this is a weekend getaway/hunting cabin so all plumbing fixtures wont be in use at the same time.
Also what couplers and fittings are best used for this project? I am doing this myself and don't have the fancy tools but I can rent them so that isn't a problem. I am hoping to use a subsoiler on my tractor to lay the pipe down but if it doesn't go quite right I will be renting a ride on trencher.
Any help or advice you can provide will be greatly appreciated!
