SWB
Update
Thanks, guys, for all your help and advice! Here's an update.
My wife and I completed Phase 1 of this project on Saturday: buying all the fittings we might need and tearing out the old pipe. What a stinky, messy, disgusting mess that was! Good thing we have an unfinished basement!
Here's some sections of the second (14-foot) length of pipe after they were cut out:
Yuck!
The entire length of this section was pretty much the same; the first (16-foot) section was much cleaner. Both were pretty much what I expected, except I expected the gunk to be a soft sludge; instead, much of it was rock hard.
After removing the pipe, I studied more closely the point where the pipe enters the basement from the sink:
My original plan was to cut this off right above the 90-degree bend and install a new 90-degree bend about an inch or so higher, thus increasing the slope towards the ductwork. That's still what I'd like to do, but notice how the pipe comes out right against the 2x10. The original installer had to burrow out part of the 2x10 to provide enough room for the flange of the elbow. If I remove this elbow, I'll be facing the same problem. How do I burrow out the 2x10 around the pipe without damaging the pipe in the process? Note that this pipe heads up into an exterior wall behind the kitchen cabinets, so there's no access from above.
Alternatively, I could leave the existing elbow alone and run new pipe from the exit of the elbow. This would give me only 0.2"/foot of slope, but it's seemed to work okay thus far: all of the blockage was in the second section that sloped at only 0.1"/foot. This section had a thin layer of soft sludge, but was generally clear.
Thoughts? Install a new elbow an inch or so higher (how to deal with the 2x10?) or leave it alone and live with only 0.2"/foot of slope for 16 feet?
Next topic: the new wye at the end of the run. I could go with a long bend:
Or I could go with a 45-degree wye:
I can mount the long bend higher on the 3" vertical, minimizing the intrusion into the living space. On the other hand, the 45-degree wye provides a steep slope at the end. I'd rather go with the long bend unless it could cause a problem.
(Ignore the location of the cap on the 2" pipe in these photos. It's not welded on yet; I just stuck it on dry to block any sewer fumes. I'm going to cut off that remaining length of pipe and cap right by the wye.)
Yuck!
Not professionally since we bought the house two years ago, but I did attack it with a hand snake last year. It helped, but when it clogged again this week, I resolved to actually fix the problem rather than just snaking it again.Cal said:Has it been snaked?
So it seems that too little slope is bad, then around 0.25"/foot is good, and more than that is bad ... except that at some point as the slope becomes more and more vertical (maybe around 45 degrees?), it obviously becomes good again. Interesting. I would like to learn more about this. (I can't help myself; I'm an engineer, and I always have to know how and why things work.) Can you direct me to a book or website that discusses this in more detail?plumguy said:1/4" per foot is not the minimum, it is the pitch you want. Too much pitch can be just as bad as not enough. ... In theory and engineering design 1/4" per foot is the correct pitch for water and solids to evenly flow downstream.
