LOCTITE PolySeamSeal Formula Tub & Tile Caulking
This is the latest tube I bought. I use the clear when I'm installing toilets. It goes on white and dries clear. It's a water cleanup, and it allows you to remove a bowl later if needed.
Instructions for installing toilets
Wellston, OK
I called Loctite and they said the 2 in 1 tub and tile caulk contains a little silicone but the 2 in 1 all purpose caulk does not contain any silicone.
WJcandee
Wise One
New York, NY
The Tub and Tile is mold-resistant.
Whatever the chemical composition, if it's the stuff Terry uses, it's the stuff with the composition that yields the results that he has been talking about: easy, residue-free removal.
