thenextdon13
Hello-
At some point in history, the local municipality changed it's water sourcing and now my water pressure is quite high (80-90PSI, I believe).
This seems to wreak havoc on my toilet and sprinkler valves, and to my understanding is quite a bit higher than it should be by code.
The main coming into the house is copper, I believe 3/4 inch. It enters through the wall at ~3' 6", then bends to vertical and joins a 'plenum' line at the ceiling level.
I'm going to add a pressure regulator in the main line, but have been trying to decide/figure out
- where to mount it (underground/box by main valve at street / in basement where main enters house
- How to support it, if in the basement (if it needs support.. is the copper itself strong enough to support the weight?)
I can update with pictures a bit later if folks feel it would be helpful..
Any input appreciated.
many thanks!
many thanks!
