awindram
I'm trying to figure out if my problem is most likely at the switch (which I can replace myself) or something more complicated (in which case I would call a pro).
Here are the facts:
1. House is only 3 years old, no electrical problems for first 6 months, everything worked properly.
2. 6 months after moving in multiple light bulbs burnt over the course of a month. Concerned that we are having surges I had a pro check things out . He determined that the installer had just used really crappy cheap bulbs and even some "pre-owned" bulbs in most of the fixtures. No problems with surges found.
3. 12 months after moving in one group of overhead can lights will only switch off if the switch is in the halfway position. This group of lights is controlled by 3 switches. (That would make them 4-way switches if I understand correctly, right?) Didn't call pro. Have just lived with it.
4. 24 months after moving in. Another overhead light will now only turn off by putting switch in halfway position. Two switches control this one overhead light. (So they are 3-way switches, right?) Didn't call pro.
5. Today (36 months after moving in) the two overhead lights in the mudroom will not turn off at all. For a few months prior, they were doing the "halfway switch to turn off" thing.
6. No electrical changes have been at all.
Being a layperson, my best guess is that our electrician used crappy switches (like the bulbs) and they are all starting to short. Is this a valid theory? What other possibilities should I consider?
Here are the facts:
