C317414
Hello,
We are in the middle of a kitchen remodel, and are installing a heavy cast iron, under-mount sink. I already installed the mounting/support for the sink, and the next step is to place the sink in the cabinet. There is not much space between the cabinet and the sink rim, so holding it by the rim will not work. I was thinking of placing a a 2x4 under the sink and running straps around it and through the drain holes. The straps would run around another 2x4 above the sink, that can be used as a lifting handle.
Do any of you have any other ideas, or suggestions on how to lift and lower the sink in place?
Thanks
Thanks
