Hi, I'm hoping some of you that are more knowledgable about plumbing can help solve my leaky tub faucet problem. I live in an apartment and have tub faucet that's constantly dripping. I wanted to see if it's something that I could easily fix on my own before involving my landlord.
I took the trim off and tried to adjust the stem using the handle but couldn't get the water to stop dripping. I did some research online and think the leak might be solved by replacing a Moen 1222 cartridge. Replacing the cartridge seems pretty straight-forward based on what I've read online, however, I wanted to consult the forum before tackling the project on my own.
First things first: would replacing the shower cartridge fix the leaky faucet problem?
Secondly, a lot of what I've read involves shutting off the main water line, but I'm not sure where that is in my building. Is it possible the two screws on either side of the stem valve control the water flow? I've included a photo of what things look like behind the wall.
I would appreciate it if someone can answer my questions. Thanks!
