Mookie3333
I have a situation where a removable bathtub 2" PVC P trap SOMETIMES leaks onto the ceiling below. The first time this happened, it was because there was a drain was blocked, and the standing water slowly found its way to trickle out of the P trap where the lock nut is. Had a plumber snake the drain, removed the trap, and retighten it, and there were no further problems.... until last night.
Last night, tenant texts me again to say there's water leaking again. This time, there is no clog, and the water is moving freely down the drain to the main stack.
What gives?? How can I assure that the lock nut is TIGHT so that no water leaks through? Teflon tape? silicone? Looking for help...... Luckily I can easily access the P trap, but I want to make this tight once and for all.
Thanks for your help guys.
