Leaky ball valve with crazy loose packing nut
Nev
I've got a 3/4" ball valve going to my water heater which ever since it was turned now slowly drips. After doing some research I saw the thing to do was tighten the packing nut but it is actually so loose that when I grabbed it the nut slid halfway off. I am not sure if threading corroded off of something or what but if I didn't know any better I'd say this nut wasn't the right size.
What are my options? Is it possible to find a replacement nut? Cleaning all the rust/calcium has made the leaking a bit worse I think...
Thanks
WorthFlorida
Solutions
Orlando, Florida
No photo. It hard to tell that the packing nut is stripped or the threads on the valve are too far gone. Someone in the past may have over tighten it. Take a picture and go to a store to see if you can match it up. With sharkbite fittings and valves available, it is not all that hard replacing the valve.
Nev
ahh, I don't know what happened to my photo. Sorry about that.
I was thinking replace as well and was looking at compression fittings at Home Depot but I didn't really know if I cut out the existing valve how I would have enough room for a new valve since I'd lose some pipe in the process
I've seen them loose from the factory. I would first see if it threads back in carefully.
Very small and they don't take much turning.
Nev
It doesn't seem like it will grab a thread at all... I can slide it right on and off like it was a size too big (except it does look the right size for the white ring behind it)
Hauppauge, NY
If you need/want to cut it out and concerned the pipe won't be long enough there are ways to deal with it without sweating in a new valve. Use a threaded valve and two thread to compression or sharkbite adapters. Yes it's a bit more expensive and there are more leak points, but no sweating is needed.
Nev
Still cheaper than a plumber, for sure! I did not think of that.
That looks like the pipe out of the valve may be soldered to the top of the water heater. That would be odd. So maybe I am misinterpreting the picture.
Sharkbite has some interesting valves, including their "Slip Ball Valves" for repair work.
https://www.sharkbite.com/products/brass-push-ball-valves
The picture definitely cuts off at the bottom in a way that is misleading. The previous water heater was a tall model and it was replaced with a short one so the installer added some extra pipe which is what I think you're seeing. Below that there is a regular big ol' nut on the top of the water heater. Home Depot recommended this 18" hose to screw into the water heater but it would be too long and I don't see a shorter one offered. https://www.sharkbite.com/products/...ed-flexible-water-heater-connector-ball-valve
From what I have been reading the sharkbites make me nervous, but I may go with one of those slip ball valves. Probably less chance of me screwing it up as long as I avoid old solder and get a clean connection.
Thanks all! I think I should be able to figure something out now
GReynolds929
Active Member
WA
Ball valves don't have packing nuts in the traditional sense. That nut is what holds the handle on. If it's leaking you need a new valve.
