YoshiGreen
I have a leaking toilet, it was leaking from the base of the toilet only when flushing the toilet. This is the only toilet in my condo that I own. So very inconvenient. My unit is in the bottom floor of my building, I have no basement or crawlspace under my unit. I have a concrete slab under my carpet (seen myself when pulling up the carpet.
I tried giving the two toilet tee bolts a little torque to see if it would help, one of the toilet tees, was completely wobbly, like there was nothing holding it in at all, extreme amounts of play.
I called a plumber, and they wanted like 200 bucks. I decided I would at least try to solve the problem myself. I thought the wax ring maybe needed to be replaced, which was less than $10, so worth at least trying!
I successfully removed the toilet to find the following. I believe the nomenclature is called a cast iron closet flange. The flange is offset from the pipe that is in the ground by about six inches (flange is not directly on top of the pipe, but is off center). The flange is metal (I believe cast iron?). It is very heavily rotted. When I lifted up the toilet the rail (I think the nomenclature is, the hole in the flange to hold to the toilet tees) broke into pieces. So I realized I have more than just a wax ring that needs replacement. The flange appears to be two pieces of separate (?) metal, one inner ring, and the outer ring. The outer ring, half of it broke off when I lifted up the toilet. I can't even slightly move the only tee that is left, it appears to be rotted into the outer ring of the flange. You can see in the picture it appears to be two pieces of metal, with some spacing in between.
How do I repair this? The rest of the outer ring doesn't seem to budge at all, can't even walk it off so I can replace it. I have tile in my bathroom.
Thanks for any help! This is my only toilet I have in my unit. I literally don't have a toilet to pee in at the moment. So I have been peeing into the bathtub drain, and taking a crap at work or at the gym.
Oh BTW, my condo HOA says it's on me to make the repair or pay the plumber, sense the toilet is leaking, and the toilet is inside my unit.
