Rashed
Hi, hope you can help because I might replace the wax ring myself - I'm assuming that the leak comes from here because the toilet is stable, and no obvious cracks in porcelain.
The toilet is sealed all round - is the water supply valve inside the system. The only possible access bolts seem to be those two on the side.
Thank you - your advice is greatly appreciated.
