JStyles
My shower was constructed about a year ago. Some of it may have been over the head of the contractor who did it, who turned out to be more of a 'handyman', good at carpentry not great at this sort of work or tiling.
I've got a leak, very definitively from the LEFT side (see photos) on my shower (the controls are on the left), the shower head is on the right. Its a large shower about 7 feet weed (we almost never use the rainhead). The left (control) side does NOT get wet, but that's where the water is coming from, under the shower its bone dry on the right (head side). It only starts leaking after a long shower, so there's some pooling going on.
I've checked behind the walls with an endoscopic camera (everyone needs one by the way) and see no water coming from the water supplies - so its a drainage problem. The whole shower needs to be caulked (he grouted corners instead of caulking them), so that's definitely a source of water entry - but despite the water seepage, there must be insufficient sealing to not accommodate for that (right?).
Shower seems to be speced correctly. Sloped mud, with a PVC liner on top of it, liner was properly wrapped up the walls, I inspected prior to tiling, no nail holes or anything dumb like that, but I'm no pro. Walls were cement board that was also Red-guarded up the ceiling. I haven't used the shower in 2 days and the grout between the corner of the floor and the wall (should be caulked) is still wet, so I'm thinking water is pooled under the tiles on the liner and is wicking all the way to the other end for some reason.
The curb is very low. On the inside of the shower there is a gap that was filled with mortar which started to crumble so I've removed. Hard to see from the photos but the liner IS in there and is correctly wrapped over the curb ... But its very low. Maybe half an inch higher than the tile surface (though again this area is far from the head and is not getting that wet ... directly).
I hope I don't need to deconstruct too much - but what should i do? I'm hoping you don't tell me rip it all out and start over
because I actually think a good amount of it is built correctly - but the curb is questionable.
I don't want to hack it - but my first instinct was to fill that gap under the curb (which I think is acting as a channel) with closed cell waterproof expanding foam and then silicone it closed. Can I patch on some extra liner and raise the curb? I'm grasping here. Thanks for your help.
