DeathSpiral
My hot water heater has been leaking from somewhere behind the Relief Value inside the WH. You can see the settlement from the water leak on the outside of the WH and the insulation at the opening of the relief value is wet. Had a plumber look at it about a year ago and he said he could try to replace the relief valve pipe (I think?), but that if he broke it, I would need a new WH. Or leave it alone and if I could deal with a minor leak, then don't do anything. So we left it alone.
Now, there is a small pubble on the floor. Water drips slighly on one of the leg stands. I assume it's leaking from the same place, but not 100% sure. Is it worth trying to get it fixed? Is the plumber able to open it up and see? Or just replace it? Not 100% sure the relief valve leaking. It's leaking in that area, but don't see a exactly where it's leaking.
The WH is a Rheem 75 gallons, model 21VR75? Any Recommendations on the brand to buy next?
Thanks. Later...
- Wayne
Thanks. Later...
- Wayne
