CollinLeon
Old Fart
I'm in the Houston area and the soil here has a high clay content. As such, digging it by hand is a real pain.
The house is a concrete slab on grade with brick veneer, built by Perry Homes. I noticed the edge of the slab being damp the other day where the brick ledge is located and right near an exterior faucet (hose bib). On the other side of the wall was my closet for the master bathroom and when I checked there, the carpet was damp by the wall. It is apparently a slow leak and I never noticed it, but the carpet was molded and ruined along that edge, so I just ripped out the carpet and padding from the closet. I had been putting off replacing it with slate or travertine for quite awhile and it looks like my hand has been forced.
I opened up the sheetrock in the closet to get to the back of the faucet and the copper line supplying it in the hope that the leak was above the slab. The copper pipe was completely dry, so no such luck. Apparently the copper pipe goes straight down through the 2x4 wall base plate and then through the concrete. Luckily it is not a major leak. By putting a squirrel cage fan blowing on it and cutting a 1" square out of the sheathing, I was able to get it to no longer dampen the concrete. The leaking water is now just draining to the brick ledge and out the house.
I've started digging by hand and have finally gotten to the bottom of the footer for the slab at that point. That means that I've only got a couple more feet to go in order to have room to get under the footer and start digging under the house and upwards to find the supply line for the faucet. As an old fart, this is not particularly that fun in a Texas summer, but once I started it, I figured I had to see it through...
I have a question though... When builders put this sort of copper pipe through the slab where the footer for the slab is located, how far do they usually go down before turning horizontally and going to wherever the water is sourced from? Do they come out the bottom of the footer before making the turn or do they make the turn while in the concrete?
So far, I have no idea whether the leak in the pipe is in the concrete or is in the soil. The clay is so impervious to water that I would not be surprised if the leak was in the portion of the pipe that was in the soil and was being forced up along the small gap between the pipe and the concrete.
