I had a slow drip leak at this connection, which is downstream from bathtub drain shoe. I removed the slip nut. Thin rubber washer was corroded, and broken. Some pipe dope was present also. I bought a new washer, but I can’t install it as drain pipe end is inside waste t connection. Is my only option to remove drain shoe on the other end so I can replace washer?
