Installed the linked Delta faucet and drain assembly.
https://www.deltafaucet.com/bathroom/product/559LF-GPM-MPU.html#undefined
The drain assembly has 3 main parts. The flange, mid piece that screws into the flange, and tail piece. When testing I first noticed a leak between rubber and sink bottom. Tightened more, no leak there.
Then noticed a leak between mid section and tail piece. I used Teflon per instructions. Tried pipe dope and leak stopped.
Then I noticed a leak around the threads under the rubber. I know it's running down the threads behind the tightening nut. Solution? Maybe pipe dope on the threads? Or silicone on the rubber to the sink? But no really sure either of those will really work.
FWIW I used plumber's putty instead of silicone around the flange. Doubt that's the problem though.
