Steve3737
Hi, I have a leaking water line under my slab with little to no hot or cold water pressure. The photo is of where my house ties into the street. I believe the leak maybe in cold water line (going to my kitchen water heater and laundry) noted by the arrow in the photo. My thought is to cut the top off of the manifold lines and install a PEX manifold with ball valves on all lines in a attempt to isolate the broken line. Then run PEX up through my attic. I'm not sure of what kind of manifold I need to do this or even if its a good idea to try for a solution. Any suggestions would be appreciated
