Charlie Bosco
Active Member
The one thing that makes me HATE plumbing is leaks! Mother EFFER! I finally get around to installing my Carbon filter and I cringe every time I need to use a threaded PVC to Brass fitting. There is NO way to test the connection without finishing the job. If it leaks the entire effing thing needs to be torn apart and redone. Only now I get to have a schitty looking coupler as a monument to my stupidity. Sorry Rant over..
I used a little teflon tape (2 wraps) and now I ended up with this photo below. Both sides are leaking at a drop every few seconds.. I am soooo pissed off I just put a bucket under it till I cool off and redo it.. There is no way to crank it down once its glued.. I have to cut it and do it over. The teflon you see in the photo was a string of it I tried to wrap around the leaking area as tight as I could.. 5 or six wraps seemed to slow it down a bit till I can repair properly..
After googling I found this..https://www.lascofittings.com/threads
I read here that the fitting should be finger tight then 1 or 2 turns.. Finger tight? Hand Tight? Everyone is different. What a BS procedure! They said no dope or Teflon. But use a sealant. But did not say what kind.
What Sealant do you suggest? I dont care about the cost. I want it to work.
In the future.. I think I am just going to prebuild the bypass with an 8" Nipple coming off both sides. One side with a cap and the other with a Hose Thread. Then I can pressurize the damn thing and look for leaks.. I can still tighten if needed.. Then just cut the nipples to fit my project.. Its more work but a lot less work than tearing this frigging thing apart and interrupting the water service.
