Leak at extrusion the element goes into, not the element
Discussion in 'Water Heater Forum, Tanks' started by jonus spector, Aug 13, 2019.
  1. jonus spector
    jonus spector New Member
    Aug 13, 2019
    Asheville NC
    Water heater, very slow leak at the lower element, not the element (changed to new one with new gasket) but where the metal that holds the element meets the tank. There is a fingered compression fitting on this extrusion. Is this fixable, how is this part attached to the tank?
  2. Terry
    Aug 17, 2004
    A photo 800 pixels or less will help us.
    How old is the tank? You can normally depend on getting ten years from an electric tank. More than that.............maybe.
  4. jonus spector
    Aug 13, 2019
    Asheville NC
    I know what your going to say, replace it. Still would like to know how that part is attached.
    the heater is approximately 30 years old.
  5. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    I was going to say to try a camera with a macro (tulip icon) setting. Then lock the focus, and move the camera closer for the snap.
  6. Terry
    Aug 17, 2004
    You're going to be replacing the tank.
  7. hj
    That is just a "friction fit" device to hold the thermostat against the tank. The leak is probably in the weld behind it.
  8. jonus spector
    Aug 13, 2019
    Asheville NC
    Terry....I'd prefer not to replace it, I'm very good at fixing things
    HJ...Is the weld on the inside or outside of the tank,
  9. Master Plumber Mark
    Master Plumber Mark Sensitivity trainer and plumber of mens souls
    Feb 6, 2005
    Sensitivity trainer.. plumber of mens souls
    Their is no way to re-weld or repair a factory welded leak hole on your electric heater.....
    as Terry stated ....you are going to need a new tank...
    I got a funny picture of what some dumbass attempted to repair with self
    tapping sheet metal screws a metal band-aid and silicone....
    this was on the second floor of his home
    we replaced it after he flooded the house
    but it did last fora few days......lol
    [​IMG]
    sedin26 likes this.
Similar Threads: Leak extrusion
Water Heater Forum, Tanks W/M aqua plus 45 indirect tank leaking Jul 17, 2019
Water Heater Forum, Tanks Possible gas leak? Jun 11, 2019
Water Heater Forum, Tanks Gas water heater. Noticed a small leak Jun 4, 2019
Water Heater Forum, Tanks Water heater leaking May 26, 2019
Water Heater Forum, Tanks Water heater temperature and pressure relief (TPR) leaking? Mar 9, 2019
