lodgera
I'm renovating the bathroom in an 1892 farmhouse that was plumbed probably in the 1940's. After I removed the toilet and got rid of the huge mess of wax and whatever flange was buried in there, I have this (new subfloor shown):
I'm guessing this is a lead flange? It is very malleable. The flange is about 6" diameter and the ID is about 3". This is a short flange/pipe (~2") that goes into a cast iron hub, which you can see in the photo below, as well as the same hub from the crawlspace.
What do I do here? Should I get one of those gasketed repair flanges that goes inside this lead pipe/flange? If that's viable, the lead flange is about .75" above the subfloor. My finished floor is only going to add maybe .3", so the lead flange is way too high. Should I cut it down to the level of the subfloor and use the gasket repair flange? Is there an easy way get the lead pipe/flange out of the cast iron so I can use a donut? Any help here is greatly appreciated.
