Chris Branscome
My home was built in 75 and still has the original galvanized plumbing, which is starting to spring pinhole leaks, so it's time to re-plumb. I'd like to go to pex but I'm uncertain if I should install a manifold. I'll describe the layout of the house and I'd love to hear how you think I should lay out the plumbing.
The water main comes in on the northeast corner of the house, on the same wall as our kitchen. The master bath is at the southwest corner of the house, the opposite corner of the kitchen. The hot water heater is in the utility room (along with our washing machine), almost perfectly in the middle of the house, about 40 feet from where the main enters the house and about 40 feet from the master bath. There's another full bathroom about 15 feet from the hot water heater, and three outside spigots.
I'm thinking of putting a manifold in the utility room, but that would mean the main water supply would come all the way to the center of the house and then go all the way back to get to the kitchen. I'm wondering if there's any reason not to do that. Should I feed the cold tap in the kitchen, and the ice maker from branches directly off of the main trunk and then feed everything else from the cold manifold?
Thanks in advance!
Thanks in advance!
