Lavatory Drain Rough-in
Replace with 1 - 1/4" Slip Joint elbow
  • yes
    Votes: 0 0.0%
  • leave it, he did it correctly
    Votes: 1 100.0%
  • Total voters
US3rnotfound
Indiana
Hi,
I recently hired a plumber to route supply and drain lines to a new single bathroom lavatory location in my master bathroom. So, after a few days have passed and we are still getting quotes on tile contractors, I noticed some things about the drain line that look odd:
1. It is 1 - 1/2" instead of 1 - 1/4".
2. The drain opening in the wall is just a PVC elbow, not threaded for an easy slip-joint installation for a standard lavatory drain.
Am I correct and do you recommend I replace this with sanitary tee that converts from 1 - 1/2" to 1 - 1/4" and have a slip-joint elbow (not sure the official name of it)?
Thank you.
US3rnotfound
Indiana
I would also have done it that way, but would NOT have glued the pipe into the elbow until I was ready to connect the sink's drain.
It's not glued in. Why would you have done it this way? What parts would I need to install a simple drain arm from a big box store when I install my vanity?
You contractor did a very nice job.
He used the correct coupling to go from copper to PVC, and it's 1.5" which is the new standard.
At finish is when the threaded adapter is glued onto the pipe stub. That allows you to place an escutcheon near the wall and then glue the adapter on afterwards. We use a 1.5" p-trap that uses a reducing slip joint washer at the tailpiece.
The trap adapters come in PVC and in ABS.
US3rnotfound
Indiana
Huh! Well alright I had no idea that the new standard is 1.5", and didn't know about that trap adapter. Thanks a lot for this info.
