Laundry sink and washer side by side far from stack
Washerbox1234
Utah
Hello all, thank you in advance for any assistance! I'm working on plumbing the new laundry room in the house and need to make sure I'm getting this right. I plan to put a sink and washing machine right next to each other, all with 2" ABS, according to this diagram:
My questions are these:
- Does this look correct for Utah code?
- Should the combo fitting be a double santee or a double fixture tee (see photo below).
- as long as the total length of the trap arm on the left for the sink doesn't exceed 60" from the vertical, could I add a long sweep 90 to turn a corner if the sink doesn't fit right next to the washer?
- The 4" main stack is approximately 30-35 pipe feet away and the run may include 5 or 6 90* bends to get around stairs and down to a lower level, is that ok as long as all the horizontal runs are sloped al 1/4" per ft? (See crude diagram(sorry)):
here's the double fixture fitting. There's a double santee available also...
Thank you so much again!!
