Timberwolf78
Hi,
First of all, great forum! I have been a long time reader and just registered as I need some help.
Here is the situation. I have a new construction in Minnesota, that has gone through various delays. The plumber that was working on my rough plumbing retired and I want to finish up where he left off.
Specifically, the DWV setup for laundry, powder room and kitchen sink. As part of finishing it up, I would like to move the washer from the original intended location.
The attached images LaundryA and LaundryB show most of where everything is currently at and the proposed new washer and laundry room wall location. Below are some highlights:
1- The waste line coming down from the toilet/vanity and connecting with the washer drain is visible.
2- It gets another drain connection from the kitchen sink right after it turns south and then goes down to the basement.
3- The kitchen sink is already vented individually.
4- There is another vent line coming out of the basement that is seen in PlumbingC and highlighted in LaundryA(you can barely see it).
5- PlumbingC shows the washer drain and the vent rough in that need to be "moved" to the new washer location.
6- The new wall location for the laundry room is highlighted in orange/yellow.
So, what is the ideal setup based on the above?
where should the drain and vent pipes(PlumbingC) be cut and washer box installed?
PlumbingNew shows the ideal vent location coming out of the powder room and going up the roof.
Most importantly where/how should the 3 vents make a connection?
I hope my description makes sense..
Thanks in advance.
Thanks in advance.
