Skoby
"Tom, we sleeve wells with 4" sch 40 pvc all the time here in western Ct, the 4" inside diameter leaves just enough room for a standard 4" pump (actual size is 3 7/8) to fit inside.
What I have done is to run my down hole camera into the well to determine where the water is coming in, could be the casing is leaking either at a joint or at the drive shoe, then I run enough 4" pvc in with a "jaswell packer" on the bottom to seal off the water coming in through the leaky casing or drive shoe. The advantage of the jaswell packer is that it can be moved further down the hole if you didn't get the bad water sealed the first time. Sometimes the pitless adapter has to be dug up in order to get the packer down through the casing."
https://terrylove.com/forums/index.php?threads/lining-a-well-casing.19822/
This member is fairly close to me but hasn't been online for a year and a half. I really need to get a camera down there.
