Wayne W.
Good evening,
We just purchased a new sink from Lowes, and a Kohler Maxton faucet. The faucet hook-up is done and fine, I am having an issue with the 1274364 drain assembly leaking. If I close the drain, and fill the basin with water, there are no leaks. However, when I open the drain and the water drains out, I get a fair amount of leakage. I have followed the installation instructions, and installed the tailpiece/drain assembly through the thin gasket, through the hole in the bottom of the basin, inserted the thicker tapered gasket (slimmer side up, to fit between the tailpiece and the basin) and then hand tightened the nut (even really snugged, but still no tools) it seems that the water spills out what would be the overflow holes, if the sink had it, and leaks out from between the tapered gasket and the basin. What else could I be missing?
