Kohler Mastershower, Please help me identify this thermostatic valve
Cobra99
Calagry
I cannot seem to find the who makes this valve.
Much appreciated.
Cobra99
Calagry
Exactly the issue I don't have that. I want to order a new trim and handle set but have no clue. This is a new purchase that was in the middle of a reno
Marlinman
Jacksonville Florida
Can you turn the service stops off and remove the thermostatic cartridge? With exceptions the majority of rough chrome valves are imported. Measurements are extremly helpful.
Cobra99
Calagry
I attempted to and it is locked up. I don't have access ATM but will try soon
Tuttles Revenge
If you're in a condo and especially if you're on an upper floor. Be Very Careful with water! Make sure you can turn off the water supply to your unit before doing anything to the frozen up service stops... If they leak, you want to be able to quickly deal with it.
Cobra99
Calagry
Hey guys,
Sorry about the delay. I was able to get this apart. The smaller one(Blue end) I think is a pressure valve?
I don't know your valve, but I wonder if the text could give useful info. Actually I am not sure that there is actual text on the right, but you might be able to tell after cleaning or moistening that end.
Cobra99
Calagry
looks like I won the lottery as the worst design and least available . Anyone know where I can get a trim kit for this that is reasonable?
Have you called Kohler? I am not a pro.
Tuttles Revenge
If Kohler doesn't have some solution available, I've had good luck finding weird old trim on Ebay.
Marlinman
Cobra99
Calagry
I've spoken to Kohler and they have no trim left for this valve. "Discontinued Kohler" on Ebay has some white trim sets left.
Thanks for the help. I reached out to the ebay seller and for the color(White doesn't work) and price it might be better to just replace. Just my luck
Tuttles Revenge
Before you dive into a remodel. You might look into having that new white fixture chromed. I've had to change the finish on a number of fixtres from Polished Brass to actual Gold plating. Just 1 option that may save you from opening walls.
Neil Binda
Toronto
I recognize this valve body and parts .
This is not Kohler .
This actually called old Sol / Riobel.
