Chad Potter
Hello. We have a Kohler 6' Bubble Massage tub that was installed circa 2011. Installed with a ClearFlo 1-1/2" bath drain. We have rarely used the tub. Recently the tub began to drain slowly. Opening and closing the drain seems to work correctly. Sometimes, the drain seems to be draining somewhat normally, but then significantly slows. So - I will close the drain and then open. Sometimes it immediately drains slowly. Sometimes it drains faster but then slows.
I took off the top to the drain and don't see any buildup / hair (and I would assume that there wouldn't be much hair buildup as the tub isn't used very much). Any suggestions as to why the tub would be draining so slowly? I've attached two photos. If you need any more, please let me know. Air jets are working normally. Thanks. Chad.
