mcotter11
This thread was extremely useful to me.
I wanted to add my experience to this thread.
We also have a Kohler Cannister/aqua-piston/class five.
I had issues with with the toliet leaking and after changing the circular valve several times, I opted to change the entire system to the flapper valve.
I ordered the kohler 04-2306 flush valve kit. It cost about $20. This is a ~ three inch flapper valve and I believe the one mentioned above in the post by user “plums away” above. The install was extremely straight forward. The only difficulty I had was that the nut under the water tank is extremely large and the tools I had on hand were not adequate to remove the nut. I needed to dremel out the old valve. Kohler recommends a spud wrench or this purpose.
The remainder of the install was very easy. YouTube videos on how to change the flush valve were helpful.
It only has been a few weeks, but the new valve kit has been working great. If the flapper fails, I hopefully can replace it with an off the shelf korkey three inch universal flapper.
Hopefully this will helpful for someone.
I have a question on how you did the replacement. I have the same issue where I have replaced the seal many many man time. My water is sandy apparently even though it is city water and not well. I purchased a Fluidmaster 400AKR to replace the entire thing.
When I pulled out all the AquaPiston parts, the gasket from the tank to the bowl has a plastic X in the middle preventing the new seal from sitting inside that (see picture). How did you get rid of this? Did you cut it out, remove the whole gasket?
