Kitchen sink with offset drain
PLS
Eastern Shore Maryland
We are renovating our kitchen, complete gut, and moving the sink to an island. I have access to drain lines in the crawl space. Sink is single bowl and has an offset drain in the back right corner so it is 5 in from the back of the sink and 5 in from the right side of the sink. Drain stub out will come through the back of the sink cabinet. Is it acceptable to locate the drain stub to the right side of the cabinet say 10 inches from the right side vs centering it in the cabinet. The water lines would then be in the center of the cabinet where normally located.
Phil
An offset is fine. With an Island sink, you will need either an AAV for venting, or what we call "Island Vent" plumbing. Lately, the plumbers here are using AAV's.
Trap and trap arm is 1.5"
Waste line to the santee is 2" with a 2" cleanout.
The AAV needs to be at least 4" above the traparm.
PLS
Thanks for more information than I asked for. I was assuming I could just use the existing vent. I am only moving the drain about 32 inches but the current drain is around 3 ft from a vent. Is the vent supposed to be within 3.5 ft of drain?
Phil
