yfstafford
I recently moved into a 1950's house and was planning on replacing the old faucet in the kitchen myself. I'm by no means handy but thought it might be relatively straight forward. However, perhaps because it is an older house, it does not seem to have a typical set up.
Looking at the pipes underneath the sink, it looks like of the two supply lines, one goes to a shut off valve while the other goes straight through the bottom of the cabinet. I know that there's typically a shut off valve to both hot and cold supply lines but is this a common setup for older houses? I've been told that the electric work on the house is weird. FWIW, apart from the main shut off valve, this is the only other one I know of in the house - none of the other sinks and toilets have shut off valves.
What would be the best way for me to connect the supply lines for my new faucet? Is this a job that will probably need a plumber?
On another note, any idea what the white box on the pipe might be for? It does not appear to be connected to anything.
Thanks for any and all help.
