The setup: ~10yr old house, I have a kitchen with a double sink under a window. Also a small sink in the island across from it. We're getting gurgling from the right side of the double sink after water is run in the double sink, or while the dishwasher is draining into it.
Here is the setup of the double sink plumbing during construction:
Each sink has a P trap and the right side has the connection to the dishwasher:
Both P traps are clean, and I've tried sticking a snake down both drains to no avail.
The problem wasn't there initially when the house was new, so I'm assuming this is due to a blockage somewhere? Is it most likely that something is partially blocked further down the main drain stack than I got with the snake? Also, how exactly is the loop vent setup on the double sink supposed to work? It kind of confuses me when I think about troubleshooting the problem.
