Kitchen sink drain question
Eric28805
Homeowner
Asheville, NC
We had a leak because of a really bad connection to the garbage disposal. Realizing how old the disposal was, I decided to get a new one. The old one had some kind of flex pipe to connect to the Tee that was a little bit lower (it is a double sink). I decided to try to keep everything level from both sinks to the Tee. That ended moving the pipe from sink on the right all the way up to the drain. Is that too close? Is there a way to make that connection, or do I need to rethink everything?
The blue disposal is the old one.
If it works, it is fine.
Many prefer a connection like shown on the second post of https://terrylove.com/forums/index.php?threads/install-garbage-disposal-in-double-sink.1736/
If you get repeated clogs at the tee, you could reconfigure. That would require you to add a slip joint 45 on the way to the wall. Or better yet, cut a double offset in half to get your 45 degrees. https://www.walmart.com/ip/Plumb-Pak-PP44W-Double-Offset-1-1-2-White/114958128
Note that the baffle in your baffle tee is different than the baffle in the tees shown in the other post.
Don't forget to knock out the knockout before hooking up the dishwasher to the disposal.
Eric28805
Homeowner
Asheville, NC
I don't actually have it connected to the sink on the right yet, but could the tee in the first photo from your link attach directly to the sink drain (sorry if I'm not calling that the right name)?
I think my main problem is that the sink on the left is more shallow, so the drain of the disposal is elevated. Maybe I should move it to the other sink?
Eric28805
Homeowner
Asheville, NC
I got a direct connection piece to connect to the sink on the right. I think I have it all done now except for the dishwasher hose. I think it fit over the connection on the old insinkerator, but it seems like it's the same diameter as the connection on the new Frigidaire disposal. It's a Bosch dishwasher, if that matters. Have the sizes changed? The old disposal was very old.
The Bosch hose end is large for the 7/8" disposer connection and further in 5/8" to fit 1/2" copper.
You have those two options with that hose.
