I have installed a single bowl, offset right drain sink in our kitchen. I have a compact disposer underneath. I have seen others with similar issues and just want to confirm if this should work or not. We went from a 7" sink to a 9" sink. It drains fine with running water. Ran the dishwasher and it ran fine. When the sink is filled it drains slow and requires opening the disposer flange. It appears to bean air issue. Will a reverse p trap help? Would placing the p trap on the disposer help? I know the horizontal pipe slopes back a little. Admittedly, it is cobbled together just to to be able to use in the short term. I hope the exit drain does not have to be lowered.
Appreciate any insight. Thanks!
