Hello.
I'm starting a kitchen remodel and looking for a little help on the drain. We have removed a kitchen half wall/bar and re-routing the drain to the back wall.
In the picture. In green are the locations of the old drain from the half wall and where I need the new drain to be located. I am utilizing the old vent and bringing it through the studs in the back wall. Planning to connect to a sanitary tee ~14" from the floor. Then the drain would go horizontal about 3'. (in red). Then connect to a long sweep 90 and then back to the drain from the prior plumbing.
My real question is whether I need a long sweep 90 for the first 3' horizontal run. I would do that but I cannot keep 1/4" slope due to a floor joist directly under that back wall. I can keep 1/4" with a standard 90.
I am having a hard time finding a definitive answer on whether a long sweep 90 is required in all situations. My prior plumbing did NOT have one. Apologies if this has been answered on prior questions. Any help would be appreciated. I will be installing a garbage disposal if that helps the discussion.
thanks for any advice.
