I have a 2060 iron filter. I noticed over the last month or two that my water pressure was getting VERY low sometimes. Normally, you can flush a toilet when the shower is running, and no one notices. Well, it got to the point where it would scald you with hot water, and then it got to the point where if you turned on water downstairs, the upstairs got NO water at all. I noticed the window in my iron filter was black. I took it out and cleaned it so I could see where the black dot was. I noticed that when on backwash mode on one side, it would stop backwashing a couple of minutes into it. One of the sides wasn't backwashing properly and since I don't have a sediment filter, it was clogged up.
Tonight, I took apart all of the layers, soaked them in CLR, scrubbed them clean with a brush, and used tiny brushes to clean out all of the holes. Most of it was caked with mud/clay (I've attached a photo of the bottom layer to show how much crap was in it). It hasn't been this clean since new. I used something called Super Lube on the O-rings and pistons inside, which is a waterproof NSF-rated lubricant with PTFE in it.
It seems to be working just fine. However, I spun a bunch of gears by hand. Was I supposed to line up the two gears on top somehow before I reassembled it? I just want to make sure that it's "not out of alignment" or assembled wrong. Like I said, it's working. I ran through 2 backwash cycles, and the third is going now.
