bitshifter
Hi, I'm working on a bathroom remodel. I've installed a kerdi shower kit and have experienced a leak in one corner of the shower kit. I read through the instructions and followed as close as possible and referenced this video as I had ditra heat installed over top the kit:
I've attached a few photos of the leak under the drain pan corner and above with the related corner. I'm curious if I used too much thin-set applying while applying kerdi band or just didn't quite get the application right. I removed the band covering the area with leak and laid it to the side for reference (attached pic). The foam support in pic was just temporary while glue dried. Any info is greatly appreciated. I can supply more images if necessary.
