Kenmore Power Miser 12 not heating adequately
Augeydoggy
New Jersey
Two days ago, the gas company did a mandatory meter replacement. Since then, our Kenmore Power Miser 12 (installed 2008), has stopped heating adequately. I have ratched up the thermostat, stopping each time that it fired. I am currently past B, the next to highest setting, but still getting only warm water, not hot.
Do I need to drain?
More than a drain, I would suggest a flush.
To do a simple water heater flush:
1. Put the WH into vacation mode, and turn off the water to the WH
2. drain the WH. Open a hot water faucet to admit air.
3. When empty, turn on the incoming water quickly for several seconds to spray against any sediment on the bottom.
4. Drain the WH.
5. Repeat #3 and #4 a few times.
6. Close the drain
7. Turn the water back on.
8. When water is freely coming out of that open faucet, close the faucet.
9. Turn the WH back on.​
Replacing the gas meter may have pushed some crud into the gas valve of your WH, and is making the operation irregular. This is more common if you do not have a drip leg on the inlet. Draining your WH isn't likely to help with a gas valve problem!
I don't know enough about them to say whether it can be resolved easily (like, if, say, it has an inlet filter, and that got clogged), or if it's more likely the gas valve needs to be replaced to clear the debris.
Master Plumber Mark
www.weilhammerplumbing.com
you are probably correct about this... your best bet is to complain to the gas company and
ask them to come out and repair this problem.. considering they made it happen in the first place...
in all likelyhood they will not help you and say its your problem
I would not attempt to just clean an old valve that is not working right
just change out the gas
thermostat to be on the safe side of things..
"stuff" in the gas line will NOT change the temperature of the unless it does NOT heat it at all. The temperature is controlled by a "sealed" element in the thermostat and is ONLY affected by conditions INSIDE the tank.
MACPLUMB
HOUSTON, TEXAS
As old as your heater is time to buy a new one, just like you would not try to repair a 9 year old computer it is not worth
the plumbing labor and parts to repair your water heater,
Can you get gas company to pay all or part ?
Dj2
California
"As old as your heater is time to buy a new one"
- Agree. Just replace this old WH and enjoy hot showers.
"Can you get gas company to pay all or part ?"
- It's a long shot. The gas co will say that your WH was already on life support.
