ENIGMA-2
I have a Kenmore water softener and one of the problem areas with this brand (it's made by Ecowater), is the control is prone to stop responding (due to corrosion.)
This has happened to me on a prior Sears unit I owned (lasted around 20 years), where the switches stopped responding, when pressed. In my latest episode, it was the "select" switch.
I'm posting this for anyone who had this type of softener and has a simular problem.
There is a quick and easy fix.
First, unplug the transformer, then unplug the three wiring harnesses (motor leads, power leads and sensor leads).
Next remove the control from the plastic face panel. (In my unit, this simply requires unclipping four clips, one in each corner, and removing the control.
With the control removed, you have access to the actual switches. Press on the switch and "massage" it while it is being pressed down (closed). This will
rub the switch contact surfaces together and dislodge the thin layer of corrosion on the internal contacts; allowing the contacts to make electrical contact once again. Reverse the procedire to reinstall. The entire repair takes about three minutes.
I use salt pellets with red out and this is probably one of the side effects that Sears warns about when using this type of salt. (Corrosive fumes). Although it could also be the salt atmosphere inside the softener that's responsible. Whatever the reason, it's an easy fix.
