C317414
Hello,
My wife and I recently bought a unit in a high rise condo. Both toilets in the unit appear to be the same, but one has a float valve of some sort that I've never seen before in a toilet. The other one may have had one at one time and it may have been removed.
It's a small float valve connected to a fairly large diameter PVC hose. The hose is a slip fit in a hole on the front wall of the toilet tank. The valve has a small vertical riser. I removed the assembly and blew into the vertical riser. With the float down, the air flowed into the hose. With the float up, the air flowed out of the valve body.
The photos show the float valve installed, as well as pulled out. I also included a photo of the numbers I found on the tank.
What's the purpose of this device?
Does anyone know the make and model of this toilet?
