Jet Pump Pressure Issue
BrianC73
Stockport, OH
I’m having a strange problem with a shallow well pump I recently installed. I also pulled and replaced the driven pipe and point. The pump primes right up to 50 PSI and will hold indefinitely. On the discharge side I have a 1” tee which transitions to a 3/4” PVC line which then is reduced down to a couple 1/2” PVC valves which will ultimately provide water to a toilet and sink. They are currently closed and no leaks present. Off the Tee I have a 3/4” bushing and then a 3/4” valve intended to serve as a drain. I have a short length of garden hose attached to it and am using it to test the set up. It works perfectly at times, with the pump kicking on just under 30 PSI and then pumping endlessly at a good volume. I noticed that once in a while the pressure will drop to zero, and after paying closer attention have found that this only occurs when I fully open the valve. If I open the valve partially, the pump kicks on at 30 PSI and flow is maintained. If I open the valve all the way, the pump kicks on but pressure quickly drops to zero. Any ideas?
Sounds like your well is producing fewer GPM than the hose can put out. Have you calculated the GPM coming out from the hose?
