Brian Keuer
Hello all.
I am looking for advice regarding the following issue(s):
We moved into a new home about 1 and 1/2 years ago. We have an irrigation/sprinkler system that has had issues with sand/grit clogging the heads, etc. The irrigation company attempted to remedy this with a sand spin-down filter in garage to no avail. Of note, the RPZ valve is installed in basement just after the air-over-water well tank. Now the RPZ valve has been getting stuck with sand/sediment. The irrigation company thinks water treatments or well company needs to remedy this. I had well company look at issue and at end of last season they pulled up well pump about 20 feet thinking that would help the sand/sediment. Now it is clear this spring that is has not. Well company came out and notes that the well tank is waterlogged and has lost air charge (in less than 6 months). They think that this causes pump to cycle more frequently, pulling sand/sediment. They propose installing air compressor to keep air charge regularly, avoid service calls to charge well tank 2-3 times a year. This seems expensive and I am not confident there is not another solution. Well company is well-respected, and they drilled original well about 2 years ago.
Is there any other issues I should have them look at regarding the sand? Is installation of air compressor on top of well tank a reasonable solution with above issues?
Thanks in advance for any comments/feedback.
